Adding and deleting path nodes
Increasing or decreasing the number of nodes on a path lets you change the shape of the line and curve segments with greater control.
Adding and deleting nodes
You can add nodes to a path if the existing segments, nodes, and control points do not let you shape a path the way you want. You can add one node at a time or several at once. When you add a node, you can choose where it displays on the line segment.
When you delete nodes, the shape of the path can change, depending on the position of the nodes that are removed.
Smoothing paths
Paths you create from masks or draw freehand style can contain more nodes than required to maintain their shape. These extra nodes can give paths a rough appearance. You can smooth the path by removing the extra nodes from the entire path or from a section of the path.
To add a node to a path Back to Top
1.
In the toolbox, click the Path tool .
2.
Click the Shape button on the property bar.
3.
Click where you want to add a node on the path.
4.
On the property bar, click the Add node button .
You can add a node at the midpoint of a path segment by selecting a node and clicking the Add node button on the property bar. The node is added between the selected node and the node that precedes it in the path.
You can also add a node by double-clicking where you want to add the node to a path segment.
To delete a node from a path Back to Top
1.
2.
3.
Select a node.
4.
On the property bar, click the Delete node button .
You can also delete a node by double-clicking it.
To smooth a path Back to Top
1.
2.
3.
Select an area of a path.
4.
On the property bar, type a value in the Smooth curve box.
You can enter values from 1 to 100. Lower values remove some nodes that are not necessary to maintain the shape of the path. Higher values remove more nodes, while still preserving the path shape.
