You can add text to enhance images. You can specify the text font, size, and alignment, as well as the character spacing and line spacing.
Text was created with the Text tool.
Text is created as an object by default; therefore, you can move, size, scale, rotate, flip, skew, distort, and apply perspective; however, you will lose distortion or perspective effects if you add, remove, or edit text characters. For more information about working with objects, see Working with objects. Text can also be rendered as an editable area of a mask. For more information about creating editable areas, see Working with masks.
You can also change the text color by filling or painting. In addition, you can fill text with patterns and textures.
You can also kern, shift, or rotate text. For more information see, Kerning, shifting, and rotating text.
| To add text |
1. |
Click the Text tool |
2. |
Choose a font from the Font list box on the property bar.
3. |
Choose a font size from the Font size list box on the property bar.
4. |
Click in the image window, and type the text.
You can render the text as an editable area by selecting the text with the Text
tool |
| To select text for modifying |
1. |
2. |
Point to the text until the pointer becomes a cursor.
3. |
Select the text.
