You can align a text object horizontally, which aligns the text in relation to its bounding box. If characters have not been shifted horizontally, applying no alignment produces the same result as applying left alignment.
| To modify text alignment |
1. |
Using the Text tool |
2. |
Click the Text alignment button on the property bar, and choose one of the
following options:
None — applies the default alignment setting
Left — aligns text with the left side of the text frame or the bounding box of
artistic text
Center — centers text within the text frame
Right — aligns text with the right side of the text frame and the bounding box
of artistic text
Full justify — aligns text, with the exception of the last line, with the left and
right sides of the text frame
Force justify — aligns text, including the last line, with the left and right sides of
the text frame
You can also align text by clicking an alignment button in the Character
formatting docker.
