Bevel effects let you create the appearance of a raised surface by applying a sloped edge along an editable area. For example, you can use bevel effects to add depth to text or create 3D buttons for the Web. You can change the angle, direction and color of the lighting, as well as apply a texture along the beveled edge. You can use a preset style or customize a preset style and save it in the preset list.
| To apply a bevel |
1. |
Select an editable area.
2. |
Click Effects |
3. |
Click the Bevel tab, and adjust the following sliders:
Height—lets you specify the depth of the bevel. The height and width settings
determine the angle of the bevel.
Smoothness—lets you specify the roundness of the beveled edge. Higher values
produce rounder edges.
4. |
Click the Lighting tab, and specify the settings you want.
