Fountain fills gradually change from one color to the next, along a linear, radial, conical, square, or rectangular path. You can use fountain fills to create the illusion of depth. You can choose a preset fill, or you can create a two-color or a custom fountain fill.
To create a custom fountain fill, you can change the colors, adjust the center point, or change the angle of a fill. You can also adjust the size of the blended area between the solid colors. When you finish creating a fountain fill, you can save it for later use as a preset.
Linear, radial, conical, and rectangular fountain fills
| To apply a preset fountain fill |
1. |
In the toolbox, click the Fill tool |
If you want to fill an object, you must select it by using the Object pick tool |
2. |
Click the Fountain fill button |
3. |
Click the Edit fill button |
4. |
In the Fountain fill dialog box, choose a preset fountain fill from the Presets list
box.
5. |
Click OK.
6. |
Click where you want to apply the fill in the image.
Merge modes control the way the foreground or fill color blends with the base
color of the image. You can change the merge mode setting from the default
(Normal) for specific blending purposes. For more information about merge
modes, see Understanding merge modes.
To apply a fill to a text object, you can first render the text as an editable area
by selecting the text object with the Text tool |
| To create a two-color fountain fill |
1. |
2. |
3. |
4. |
In the Fountain fill dialog box, choose a fountain fill from the Presets list box.
5. |
Choose a fountain fill type from the Type list box.
6. |
Enable the Two color option in the Color blend area.
7. |
Open the following color pickers, and click a color:
From — determines the start color for the progression
To — determines the end color for the progression
8. |
Move the Mid-point slider to set the midpoint between the two colors.
9. |
Click one of the following:
Direct color path |
Counterclockwise color path |
Clockwise color path |
| To create a custom fountain fill |
1. |
2. |
3. |
4. |
5. |
6. |
Enable the Custom option in the Color blend area.
7. |
Double-click the area above the Color band to add a color marker, and click a
color on the color palette.
If you want to change the location of a color marker, drag it to a new position. |
Custom fountain fills can contain up to 99 colors.
You can delete a color marker by double-clicking it.
You can change the color of a color marker by clicking the color marker and
clicking a color on the color palette.
