Applying new special effects
Premium feature
In Corel PHOTO-PAINT, you can apply several new camera effects to adjust the color and tone of photos. You can also define an area of focus with the Bokeh Blur effect. For more information about special effects, see Applying special effects.
The Time machine effect recreates photographic styles from the past.
The new special effects are
Bokeh blur — lets you control the amount of blur applied to the outside of an editable area and adjust the transition between the area in focus and the blurred area. You can also choose between circular and hexagonal aperture shapes. The aperture shape can affect light patterns that appear in the out-of-focus areas. This effect is most noticeable in small pinpoints of light on a dark background. For example, it can be used to simulate the way a camera lens handles lights that are out of focus. This effect can also be used effectively in combination with the Planar mask tool. For more information, see Using the Planar Mask tool.
Colorize — lets you replace all colors in an image with a single color (or hue) to create a duotone image. You can then adjust the saturation or vividness of the color. A color with 100% saturation contains no white. A color with 0% saturation corresponds to a shade of gray. With this effect, you can create various single-color images. For example, a brownish hue can create a sepia effect, simulating the color of old photographs.
Sepia toning — simulates the look created when you take a photo with sepia film. Sepia-toned images are similar to black-and-white photos (also known as grayscale photos), except the tones are brown instead of gray.
Time machine — lets you walk your image back through history to recreate some popular photographic styles from the past. You can choose from seven styles, which range from the year 1839 to the 1960s.
The Bokeh blur effect has been used to define an area of focus in the middle, leaving the rest of the photo out of focus.
To apply the Bokeh Blur effect Back to Top
1.
Using a mask tool, select the area of the image that you want to keep in focus.
2.
Click Effects Blur Bokeh blur.
3.
In the Bokeh blur dialog box, perform a task from the following table.
To
Do the following
Invert the selected area
Enable the Invert mask check box.
Adjust the amount of blur in the area that is out of focus
Move the Blur amount slider.
Moving the slider to the right increases the blur; moving the slider to the left decreases the blur.
Specify the aperture shape for the blurred area
Enable one of the following options in the Aperture shape area:
Circular
Hexagonal
Adjust the transition between the area in focus and the blurred area
Move the Feather edge slider.
Moving the slider to the right increases the feathering; moving the slider to the left decreases the feathering.
Fine-tune the size of the area in focus
Move the Focus range slider to the left to shrink the area in focus, or move the slider to the right to expand the area in focus to the edge of the selection.
Make your selection slightly larger than the area you want to keep in focus, and then fine-tune the edge of the selection by using the Focus range slider.
To apply camera effects Back to Top
1.
Click Effects Camera, and choose one of the following effects:
Colorize
Sepia toning
Time machine
2.
In the dialog box, specify the settings you want.
Camera effects
Original
Colorize
Sepia toning
Time machine
