Uniform fills are the simplest fill type. They are solid colors that you can apply to images.
Uniform fills can be applied to the background, an object, or a particular color.
| To apply a uniform fill |
1. |
In the toolbox, click the Fill tool |
2. |
Click the Uniform fill button |
3. |
Click the Edit fill button |
4. |
In the Uniform fill dialog box, choose a color model from the Model list box.
5. |
Click a color in the visual selection area.
6. |
Click OK.
7. |
Click where you want to apply the fill in the image.
You can choose the colors for a uniform fill from an image, or by accessing color
models, mixers, or fixed or custom palettes. For information about choosing
colors, see Working with color.
Merge modes control the way the foreground or fill color blends with the base
color of the image. You can change the merge mode setting from the default
(Normal) for specific blending purposes. For more information about merge
modes, see Understanding merge modes.
You can also select a fill color by right-clicking a color on the color palette.
