Computer Graphics Metafile (CGM) is an open, platform-independent metafile format used for storing and exchanging two-dimensional graphics. It supports RGB color. CGM files can contain both vector graphics and bitmaps, but they usually contain one graphic type or the other — rarely both.
| To import a CGM file |
1. |
Click File |
2. |
Locate the folder in which the file is stored.
3. |
Do one of the following:
(Windows 7 and Windows Vista) Choose CGM - Computer Graphics Metafile
(*.cgm) from the list box next to the File name box.
(Windows XP) Choose CGM - Computer Graphics Metafile from the Files of
type list box.
4. |
Click the filename.
5. |
Click Import.
The Convert to bitmap dialog box appears. |
| Computer Graphics Metafile (CGM) technical notes |
You can import files formatted in CGM versions 1, 3, and 4.
The CGM filter accepts only markers supported by the CGM file format standard.
Private-use markers are ignored.
If the CGM file contains a font that is not on your computer, the PANOSE font-
matching dialog box lets you replace the font with an available one.
