EPS files can contain text, vector graphics, and bitmaps and are intended to be included (encapsulated) in other documents. Unlike other PostScript files, which can contain multiple pages, an EPS file is always a single page.
EPS files usually contain a preview image (header) that lets you view the file content without the help of a PostScript interpreter. An EPS file without a preview image is displayed as a gray box in Corel applications.
| To import an encapsulated PostScript file |
1. |
Click File |
The File |
2. |
Locate the folder in which the file is stored.
3. |
Do one of the following:
(Windows 7 and Windows Vista) Choose PS, EPS, PRN - PostScript (*.ps;
*.eps; *.prn) from the list box next to the File name box.
(Windows XP) Choose PS, EPS, PRN - PostScript from the Files of type list
box.
4. |
Click the filename.
5. |
Click Import.
6. |
Click OK.
7. |
Click the image window.
8. |
In the Convert to bitmap dialog box, adjust the width, height, resolution, color
mode, or any of the other settings.
| To save to an encapsulated PostScript file |
1. |
Click File |
2. |
Locate the folder in which you want to save the file.
3. |
Choose EPS - Encapsulated PostScript from the Save as type list box.
4. |
Type a filename in the File name list box.
5. |
Click Export.
6. |
In the EPS export dialog box, adjust any of the settings.
| To set general exporting options |
In the EPS export dialog box, perform one or more tasks from the following table:
If you choose the 8-bit TIFF format for previewing images, you can make the
background of the bitmap transparent by enabling the Transparent
background check box in the Preview image area.
| To specify clipping options |
1. |
In the Clipping area of the EPS export dialog box, enable the Clip to check box.
2. |
Enable any of the following options:
Mask — lets you save the contents of the mask area to an EPS file
Clipping path — lets you save the contents of either the active path or one of
the paths listed in the MRU list box
3. |
In the Flatness box, type a value to set the accuracy with which curved path
segments are rendered on an output device, such as a printer.
If you want to permanently remove the sections of the image that are outside the mask or path, enable the Discard image data outside clipping region check box. |
| To install Ghostscript |
1. |
Close any open programs.
2. |
On the Windows taskbar, click Start |
3. |
In Windows 7 or Windows Vista, click Uninstall a program.
In Windows XP, click the Add or remove programs icon.
4. |
In Windows 7 or Windows Vista, double-click CorelDRAW Graphics Suite X6
from the Uninstall or change a program page.
In Windows XP, choose CorelDRAW Graphics Suite X6 from the Currently
installed programs list.
5. |
Click Modify.
6. |
Click the Features tab.
7. |
Enable the GPL Ghostscript check box.
8. |
Follow the instructions in the installation wizard.
| Encapsulated PostScript (EPS) technical notes |
In Corel PHOTO-PAINT, EPS files are imported as bitmaps.
Duotone information is preserved only in EPS files created in
Corel PHOTO-PAINT. When you import a duotone EPS file created in
CorelDRAW, the file is converted to grayscale.
On a PostScript printer, graphics exported to the encapsulated PostScript (EPS)
format print from other programs exactly as they do from a Corel graphics
programs.
You can save a header to the Tagged Image file format (TIFF) or Windows Metafile
format (WMF) in black and white, 4-bit grayscale or color, or 8-bit grayscale or
color. You can set the header resolution between 1 and 300 dots per inch (dpi); the
default header resolution is 72 dpi. If the program importing the EPS file has a
limitation on the image header size, you might receive an error message stating
that the file is too large. To reduce file size, in the EPS export dialog box, choose
Black and White from the Mode box, and lower the header resolution before
exporting the file. The setting determines only the resolution of the header and has
no impact on the print quality of a drawing. Color headers are useful for viewing
EPS files. If the program in which you are going to use the file does not support
color headers, try exporting with a mono header instead. You can also export
without a header.
Along with the graphic, exported EPS files contain a filename, program name, and
date.
