Exporting images for the Web
Corel PHOTO-PAINT lets you export the following Web-compatible file formats: GIF, PNG, and JPEG.
While specifying exporting options, you can preview an image with up to four different configurations of settings. You can compare file formats, preset settings, download speeds, compression, file size, image quality, and color range. You can also examine previews by zooming and panning within the preview windows.
Component
Description
1. Preview window
Displays a preview of the document.
2. Preview modes
Lets you preview the adjustments in a single or split frame.
3. Zooming and panning tools
Lets you zoom in and out of an image displayed in the preview window, pan an image displayed at zoom level higher than 100%, and fit an image to the preview window.
4. Eyedropper tool and sampled color swatch
Lets you sample a color and display the sampled color.
5. Preset list box
Lets you choose preset settings for a file format.
6. Export settings
Lets you customize export settings, such as color, display options, and size.
7. Format information
Lets you view file-format information, which is available for each preview frame.
8. Color information
Displays the color values for a selected color.
9. Speed list box
Lets you choose an Internet speed for saving the file.
You can export Web-compatible files using preset settings. This allows you to optimize the file, without the need to modify individual settings. You can also customize the settings to produce a specific result. For example, you can adjust its color, display quality, and file size.
Choosing a Web-compatible file format
This table is a quick reference for choosing a Web-compatible file format.
File format
Ideal for
GIF
Line drawings, text, images with few colors, or images with sharp edges, such as scanned black-and-white images or a logos.
GIF offers several advanced graphic options, including transparent backgrounds, interlaced images, and animation. It also lets you create custom palettes for the image.
PNG
Various image types, including photos and line drawings.
The PNG file format (unlike the GIF and JPEG formats) supports the alpha channel. This allows you to save transparent images with superior results.
JPEG
Photos and scanned images.
JPEG files use file compression to store an approximation of an image, which results in some loss of image data, but does not compromise the quality of most photographs. You can choose the image quality when you save an image — the higher the image quality, the larger the file size.
Exporting palette-based images
Palette-based images, such as paletted GIF and 8-bit PNG, allow individual pixels to retain their exact color value. This lets you control the display of colors in the file when exporting. Palette-based images also allow you to introduce transparency to a file by choosing a color in the image and making it transparent. For information, see Creating palette-based images with transparent colors and backgrounds.
To adjust the image-export preview |
1. |
Click File Export for Web.
2. |
Perform one or more tasks from the following table.
To
Do the following
View the object in a single preview frame
Click the Full preview button on the View toolbar.
View two versions of the object in side-by-side frames
Click the Two vertical previews button .
View the two versions of the object with one frame placed above the other
Click the Two horizontal previews button .
View four versions of the object in separate frames
Click the Four previews button .
Fit an object in the preview window
Click the Zoom to fit button .
Display each pixel in the image data to a single pixel on-screen
Click the Zoom 1:1 pixel button .
Pan to another area of an object
Using the Pan tool , drag the image until the area you want to see is visible.
Display an object at its actual size
Click the 100% button .
Zoom in and out
Using the Zoom in tool or Zoom out tool , click in the preview window.
Change the display options for the object in a preview frame
Click a frame, then choose different export settings from the export settings area.
To export a Web-compatible image |
1. |
2. |
In the Export for Web dialog box, choose preset settings from the Preset list box
in the upper-right corner of the dialog box.
If you want modify the preset settings, you can change the exporting options in the dialog box. |
4. |
Choose the drive and folder where you want to save the file.
5. |
Type a name in the File name box.
To
Do the following
Choose a color mode
In the Settings area, choose a color mode from the Color mode list box.
This option is unavailable for the GIF file format.
Embed the color profile
In the Advanced area, enable the Embed color profile check box.
You can also export to a Web-compatible format by clicking File Export,
and choosing a file format from the Save as type list box.
You can choose an Internet connection speed from the Speed list box at the
bottom of the dialog box.
To resize an image when exporting a Web-compatible image |
From the Export to Web dialog box, perform one or more tasks from the following
table.
To
Do the following
Choose a unit of measurement for the object
In the Transformation area, choose a unit of measurement from the Units list box.
Specify the object dimensions
In the Transformation area, type values in the Width and Height boxes.
Resize the object to a percentage of its original size
In the Transformation area, type values in the Width % and Height % boxes.
Avoid distortion by maintaining the width-to-height ratio of the image
In the Transformation area, enable the Maintain aspect ratio check box.
Specify the object resolution
In the Transformation area, type a value in the Resolution box.
Maintain the size of the file on your hard disk when you change the resolution of the object
In the Transformation area, enable the Maintain size check box.
To customize options for exporting a JPEG bitmap |
1. |
From the Export to Web dialog box, choose JPEG from the Format list box.
2. |
To
Do the following
Control image quality
In the Settings area, choose a quality option from the Quality list box, or type a percentage value.
Choose an encoding setting
In the Settings area, choose an option from the Sub-format list box.
Blur the transition between adjacent pixels of different colors
In the Settings area, type a value in the Blur box.
Load the JPEG image gradually in certain Web browsers to display portions of the image before it finishes loading
In the Advanced area, enable the Progressive check box.
Use the optimal encoding method to produce the smallest JPEG file size
In the Advanced area, enable the Optimize check box.
You can also
Apply the document-color settings
In the Advanced area, enable the Use document color settings option.
Apply the color-proof settings to the document
In the Advanced area, enable the Use color proof settings option.
Enable the overprinting of black when exporting to CMYK
In the Settings area, enable the Overprint black check box.
Apply a matte color to the object’s background to help blend the edges of anti-aliased objects
In the Settings area, open the Matte color picker, and click a color.
To specify display-quality options for exporting Web-compatible images |
table.
To
Do the following
Smooths the edges of the object
In the Advanced area, enable the Anti-aliased check box.
Load the file gradually in certain Web browsers to display only portions of the image before it finishes loading
In the Advanced area, enable the Interlaced check box.
To specify color settings for exporting palette-based Web-compatible images |
table.
To
Do the following
Choose a color mode
Choose a color palette
In the Settings area, choose a palette from the Color palette list box.
Specify a dithering setting and amount
In the Settings area, choose a dithering option from the Dithering list box, and type a value in the box.
You can also
Load a color palette
In the Settings area, click the arrow next to Color palette list box, and click Load palette.
Sample a color and add it to a color palette
Click the Eyedropper on the toolbar, and then click in the image to choose a color. In the Settings area, click the Add the sampled color to palette button .
Add or modify colors
Double-click a color swatch on the color palette.
Choose the number of colors that you want to display
In the Settings area, choose a value from the Number of colors list box.
Delete a color from the color palette
In the Settings area, click a color on the color palette, and then click the Delete the selected color button.
