You can decrease printing time by specifying driver compatibility for non-PostScript printing devices. For more information, see Printing colors accurately.
If a printing device has difficulty processing large bitmaps, you can divide a bitmap into smaller, more manageable chunks by setting an output threshold. If any lines appear when the printing device prints the chunks, you can set an overlap value to produce a seamless image.
To reduce file size, you can downsample images. Because images are made up of pixels, when you downsample an image, the number of pixels per line decreases, which decreases the file size.
| To specify driver compatibility settings |
1. |
Click Tools |
2. |
In the list of categories, double-click Global, double-click Printing, and click
Driver compatibility.
3. |
Choose a non-PostScript printing device from the Printer list box.
4. |
Enable any of the check boxes that correspond to the settings that you want to
specify.
| To choose a threshold and chunk overlap |
1. |
Click Tools |
2. |
In the list of categories, double-click Global, and click Printing.
3. |
From the Special settings list, choose one of the following:
Bitmap output threshold (K)
Bitmap chunk overlap pixels
4. |
Choose a value from the Setting list box.
| To downsample images |
1. |
Click File |
2. |
Click the Prepress tab.
3. |
In the Bitmap downsampling area, enable any of the following check boxes and
type a value in the corresponding box:
Color and grayscale
Monochrome
