After you create a path, you can fit text to it to place text along a line or shape. After you fit text to a path, you can adjust the position of the text in relation to the path. For example, you can place text on the inside or outside of the path, or you can adjust the distance between text and a path.
You can render text as an object to separate it from a path; the text retains the shape of the path to which it was fitted. You can also straighten text to separate it from the path without retaining the path shape. For more information about creating paths, see Creating paths.
| To fit text to a path |
1. |
In the toolbox, click the Object pick tool |
2. |
Select the text.
3. |
Click Object |
4. |
Click a path at the point where you want the text to begin.
You can also fit text to a path by clicking the Text tool |
You can create text along a path.
| To adjust the position of text fitted to a path |
1. |
Select the text by using the Text tool |
2. |
On the property bar, choose a setting from any of the following list boxes:
Text orientation — sets the orientation of text
Vertical placement — sets the vertical position of text
Text placement — sets the placement of text
Distance from path — sets the distance between the text and the path
Offset — sets the horizontal position of text
If you want to move text to the opposite side of the path, click the Place on other side button |
You can also adjust text by selecting the text with the Object pick tool |
| To render text as an object |
1. |
2. |
Select the text.
3. |
Click Object |
You can render the text as an editable area by selecting the text object with the
Text tool |
| To straighten text |
1. |
2. |
Select the text.
3. |
Click Object |
