You can save one or more paths with an image when you save the image to the Corel PHOTO-PAINT (CPT) file format. You can also export paths for use in other applications, such as CorelDRAW (CDR) or Adobe Illustrator (AI). If you want to use a path in other Corel PHOTO-PAINT images, you must export the path to the Corel Presentation Exchange (CMX) file format. You can delete a path at any time.
You can import a path into a Corel PHOTO-PAINT image. You can open more than one path and switch between them in the image window. Corel PHOTO-PAINT also lets you import vector graphics from other drawing applications. When vector graphics are converted to paths, each point on the vector is converted to a node. To import text from CorelDRAW, you must first convert the text to curves.
By default, a path displays in black. You can hide a path when you are working on an image, or you can change the default color of the path to make it more visible.
| To save a path with an image |
1. |
Click File |
2. |
Choose the folder where you want to save the file.
3. |
Type a name for the image in the File name box.
4. |
Choose Corel PHOTO-PAINT image from the Save as type list box.
You must export a path if you want to use it in other Corel PHOTO-PAINT
images or other applications. For information about exporting paths, see To
export a path.
| To export a path |
1. |
Click a path in the Path docker.
If the Path docker is not open, click Window |
2. |
Click the flyout button in the Path docker, and click Export path.
3. |
Choose the folder where you want to save the path.
4. |
Type a filename in the File name box.
5. |
Choose a file type from the Save as type list box.
| To delete a path |
1. |
2. |
Click the Delete current path button |
| To import a path or vector graphic |
1. |
Click the flyout button in the Path docker, and click Import path.
2. |
Choose the folder where the path or vector graphic is stored.
3. |
Double-click the filename.
Large, complex vector images are not suitable for importing as paths, because
they contain too many nodes.
| To hide a path |
Click the Show/hide path button in the Path docker.
| To change the default path color |
1. |
Click Tools |
2. |
In the Workspace list of categories, click Display.
3. |
Open the Path color picker, and click a color.
