You can open most bitmaps in Corel PHOTO-PAINT. Each image you open appears in its own image window.
You can also import images. Importing allows you to add a new image to the active image window. For more information, see Importing files.
You can use the clipart and photos that are included on the Corel DVD. If you are using Windows 7 or Windows Vista, you can search for images by different criteria, such as filename, title, subject, author, keyword, comment, and other properties attached to the file. For more information about searching for files with Windows 7 or Windows Vista, see the Windows Help. If your operating system is Windows XP, you can use Windows Desktop Search to find files. You can also browse and search for content by using Corel CONNECT. For more information, see Exploring Corel CONNECT.
You can open or import an image from version 11 or earlier of Corel PHOTO-PAINT that contains text in a language different from the language of your operating system. To do this, you can use code page settings to ensure that object names and notes saved with the image are displayed correctly in the Objects docker. To ensure that text is correctly displayed in the image window, you need to use encoding settings. For more information, see Modifying encoding settings to display text correctly.
| To open an image |
1. |
Click File |
2. |
Locate the folder where the file is stored.
3. |
Click a filename.
If necessary, you can search for an image by using the search box. You can search by filename, title, subject, author, keyword, or comment. |
To search for user-identified tags with Windows XP, you must have Windows Desktop Search installed on your computer. |
4. |
Click Open.
You can also open an image by clicking the Open button |
| To insert a file into an active image |
Drag the image or sound file to the image window.
You can also open a file in a new image window by dragging the file to the
application window.
