You can save a brushstroke and then reapply it to the same image or other images. You can also repeat a brushstroke along the border of a path or mask. For information about applying a brushstroke to a path, see Applying brushstrokes to paths.
You can edit a saved brushstroke to create new effects by adjusting attributes such as the size, number, angle, and color of the brushstroke.
| To save a brushstroke |
1. |
In the toolbox, click the Paint tool |
2. |
On the property bar, open the Brush category picker, and click a tool.
3. |
Choose a brushstroke from the Brush type list box.
4. |
Click Edit |
5. |
In the Repeat stroke dialog box, click the Stroke flyout arrow, and click Add last
tool stroke.
6. |
Choose the folder where you want to save the brushstroke.
7. |
Type a filename in the Filename box.
| To apply a saved brushstroke |
1. |
2. |
3. |
Click Edit |
If there are two menu items called Repeat brushstroke, click the second one. |
4. |
Choose a brushstroke from the Stroke list box.
5. |
Click in the image window to apply the brushstroke.
If you want to apply more than one brushstroke, continue clicking. |
| To edit a saved brushstroke |
1. |
2. |
3. |
Click Edit |
4. |
In the Repeat stroke dialog box, choose a saved brushstroke from the Stroke list
box.
5. |
In the Repeat stroke dialog box, modify any attributes.
6. |
