Since only one mask can be active in an image, each new mask you create replaces the current mask. However, before you create a mask, you can save the current mask to an alpha channel in the image so that it can be reused. When you save an image to a file format that supports mask information, such as Corel PHOTO-PAINT (CPT) or TIFF, the current mask and all alpha channels are saved with the image.
You can also save the current mask or an alpha channel to disk as a separate file. Saving a mask or an alpha channel lets you use masks in other images. This is especially useful if you want to save an image to a file format that doesn’t support mask information but you want to keep copies of the masks used to edit that image. A color mask can also be saved to disk as a separate file. For more information about color masks, see Defining editable areas by using color information.
| To save the current mask to an alpha channel in an image |
1. |
Click Mask |
2. |
Type the name of the new or existing alpha channel in the As box.
| To save a mask to disk |
1. |
Click Mask |
2. |
Choose the folder where you want to save the mask.
3. |
Type a filename in the File name box.
4. |
Choose a file type from the Save as type list box.
5. |
Click Save.
| To save an alpha channel to disk |
1. |
In the Channels docker, click an alpha channel.
If the Channels docker is not open, click Window |
2. |
Click the Flyout button |
3. |
In the Save an alpha channel to disk dialog box, choose the folder where you
want to save the alpha channel.
4. |
5. |
6. |
Click Save.
| To save a color mask to disk |
1. |
Click Mask |
2. |
Create a color mask.
3. |
Click the flyout button, and click Save color mask.
4. |
Choose the folder where you want to save the color mask.
5. |
6. |
Click Save.
