You can paint with small-scale, full-color bitmaps, instead of a brush. For example, you can enhance landscapes by spraying clouds across the sky or foliage across the ground.
Corel PHOTO-PAINT includes a variety of images, which are used to create spraylists. You can load a preset spraylist, edit a preset, or create a spraylist by saving images in an image list. You can edit the source images at any time.
In addition, CorelDRAW Graphics Suite X6 provides a collection of image lists that you can use. For information about accessing these image lists, see Accessing content.
In this example, butterflies have been sprayed around the rose.
| To spray images |
1. |
In the toolbox, click the Image sprayer tool |
2. |
Choose a preset image list from the Brush type list box on the property bar.
3. |
Type a value in the Size box on the property bar.
4. |
Drag in the image window.
The minimum and maximum numeric values for a box on the property bar can
be displayed by right-clicking in the box to open the Settings dialog box.
| To load an image list |
1. |
2. |
Click the Browse button |
3. |
Choose the folder where the image list is stored.
4. |
Click a filename.
If you want to view a thumbnail of the image list, enable the Preview check box. |
5. |
Click Import.
| To create a spraylist |
1. |
2. |
3. |
Click the Create spraylist button |
4. |
In the Create spraylist dialog box, specify the contents of the spraylist.
| To create an image list from an object |
1. |
Using the Object pick |
2. |
3. |
In the Brush settings docker, click the flyout button |
If the Brush settings docker is not open, click Window |
4. |
Choose the folder where you want to save the image list.
5. |
Type a filename in the Filename box.
| To create an image list from an image |
1. |
2. |
3. |
Type values in any of the following boxes:
Images per row — lets you specify the number of horizontal tiles in the image
list
Images per column — lets you specify the number of vertical tiles in the image
list
Number of images — lets you specify the number of images to include in the
list
4. |
Click OK.
5. |
6. |
| To edit a source image |
1. |
2. |
3. |
Edit the source image.
If you want to overwrite the last version of the image list, click File |
After you edit an image list, you must reload it in the Image sprayer tool to
activate the changes.
