Using a pressure-sensitive pen
Corel PHOTO-PAINT provides settings that let you control brushstrokes when you use a pressure-sensitive pen, or stylus. The pressure applied with the pen on a pen tablet determines the size, opacity, and other attributes of the brushstroke.
Corel PHOTO-PAINT automatically configures pen tablets. You can manually configure older pen tablets.
You can assign a different tool to each pressure-sensitive pen and eraser available with the pen tablet. You can also set the pen attributes. Some pressure-sensitive pen attributes are set in percentages; others are set in angles; size is set in pixels. Positive values increase a brush tool attribute as you add pressure to the pen, resulting in a more pronounced effect. Negative values make a brush tool attribute less pronounced as you add pressure.
The pressure-sensitive pen attributes can be saved for future use when you save a custom brush. For more information about custom brushes, see Creating custom brushes.
To configure a pen tablet Back to Top
1.
Click Tools Options.
2.
In the Workspace list of categories, click General.
3.
In the Pen tablet area, click the Configure button.
4.
Using a full range of pressure, apply five strokes.
Corel PHOTO-PAINT automatically configures many pressure-sensitive pens. If your pressure-sensitive pen has been configured automatically, the Configure button appears grayed.
To assign a tool to a pressure-sensitive pen Back to Top
1.
2.
3.
In the Pen tablet area, enable the Save last used tool for each stylus check box.
4.
Click OK.
5.
Click a paint tool with the pressure-sensitive pen.
To assign a tool to the eraser of a pressure-sensitive pen Back to Top
1.
In the Brush settings docker, click the Eraser options button on the Pen settings bar.
If the Brush settings docker is not open, click Window Dockers Brush settings.
2.
Click a tool.
To set the attributes of a pressure-sensitive pen Back to Top
1.
In the toolbox, click the Paint tool .
2.
On the property bar, open the Brush category picker, and click a paint tool.
3.
In the Brush settings docker, click the flyout arrow on the Pen settings bar.
4.
Type values in any of the following boxes:
Size — lets you specify the size of the brush tool. Use a value from -999 to 999.
Opacity — lets you adjust the transparency of the brushstroke. Positive or negative values have no impact if the transparency of the tool is set to 0 or is already set to the maximum. Use a value from -99 to 100.
Soft edge — lets you specify the width of the transparent edge along a brushstroke. Use a value from -99 to 100.
Hue — lets you shift the hue of the paint color around the Color Wheel up to the specified degree
Saturation — represents the maximum variation in the saturation of the paint color. Use a value from -100 to 100.
Lightness — represents the maximum variation of lightness of the paint color. Use a value from -100 to 100.
Texture — lets you specify the amount of texture visible for the current paint tool. Use a value from -100 to 100.
Bleed — lets you specify how quickly a brushstroke runs out of paint. Use a value from -100 to 100.
Sustain color — works in conjunction with the bleed value to adjust the traces of paint that remain throughout the brushstroke. Use a value from -100 to 100.
Elongation — represents the amount of tilt and rotation of the pen. Use a value from 0 to 999.
5.
Drag the pen, varying the amount of pressure you apply to the tablet, to test the attributes.
To vary the shape of artistic nibs which do not support pressure-sensitive sizing, use variants of circular and rectangular nibs.
