Clipping paths let you create non-rectangular images by outlining the area selected by a path, and making the rest of the image transparent when the image is viewed in another application. For example, if you have a Corel PHOTO-PAINT image of a vase on a table, you can create a clipping path around the vase and export the vase image area to another application. If you do not use a clipping path, the entire image is encased in a square or rectangular frame, losing the shape of the vase area.
To send a clipping path to another application, you must export the contents of the path as an encapsulated PostScript (EPS) file. You can also print the area enclosed by a clipping path and specify a flatness value that controls the accuracy with which curved path segments are rendered on an output device, such as a printer.
| To create a clipping path |
1. |
Create a path around an image area.
2. |
Click the flyout button in the Path docker, and click Set as clipping path.
If the Path docker is not open, click Window |
A clipping path icon displays beside the path filename in the Path docker.
| To save a clipping path as an EPS file |
1. |
Click File |
2. |
Choose the folder where you want to save the clipping path.
3. |
Type a filename in the File name box.
4. |
Choose Encapsulated PostScript from the Save as type list box.
5. |
In the Image header area, enable the Include thumbnail check box.
6. |
In the Clipping area, enable the Clip to check box.
7. |
Enable the Clipping path option.
8. |
Type a value in the Flatness box.
9. |
Enable the Discard image data outside clipping region check box.
You can save an entire image with a path by disabling the Discard image data
outside clipping region check box. However, only the selection inside the
clipping path is printed on a PostScript printer.
| To print the area enclosed by a clipping path |
1. |
Click File |
2. |
Click the PostScript tab.
3. |
Type a value in the Set flatness to box.
