Working with object transparency
You can change the transparency of an object to reveal image elements that lie beneath it. When you change the transparency of an object, you change the grayscale value of its individual pixels.
Most changes to the transparency of an object are permanent. If you want to apply transparency changes separately, so the object is not affected, you can use a clip mask. For more information, see Using clip masks.
Changing object transparency
You can change the transparency of an entire object, or the transparency of an editable area. Changing the transparency alters the transparency values of all pixels in the object or editable area by an equal amount.
The object has been flipped to create a reflection in water, and transparency has been applied to the reflection.
Applying transparency gradients to objects
You can apply a transparency gradient to an object so that the object fades from one transparency value to another. There are several gradient types that determine the pattern of the transparency: flat, linear, elliptical, radial, rectangular, square, conical, bitmap, or textured.
You can customize the gradient by adding and removing nodes, and specifying a transparency value for each node.
Making selected colors in objects transparent
You can make all pixels of a certain color or color range transparent in the active object. Removing one or all of the color selection nodes makes the pixels of a certain color opaque again.
Blending objects
You can create interesting effects by blending objects with other objects that are below them in the stacking order, or by blending objects with the background. As you experiment with settings, the transparency effect previews in the image window.
To change the transparency of an object Back to Top
1.
Select an object.
2.
In the Objects docker, type a value (0 to 100) in the Opacity box.
If the Objects docker is not open, click Window Dockers Objects.
Transparent objects have a grayscale value of 0, and opaque objects have a grayscale value of 255.
The Opacity box is not available for black-and-white (1-bit) images.
To change the transparency of part of an object Back to Top
1.
Select an object.
2.
In the toolbox, click the Object transparency brush tool .
3.
On the property bar, open the Nib Shape picker, and click a shape.
4.
Type a value in the Size box.
5.
Type a value in the Transparency box to set the transparency level for the brushstroke.
6.
Drag across the object.
You can quickly choose a square or round brush shape by clicking the Round nib button or the Square nib button on the property bar.
To apply a transparency gradient to an object Back to Top
1.
Select an object.
2.
In the toolbox, click the Object transparency tool .
3.
On the property bar, choose a gradient from the Fill type list box.
4.
In the image window, drag the nodes to set the gradient arrow.
5.
Click a node, and type a value in the Transparency box on the property bar.
6.
Click the Apply transformation button .
You can also
Modify a transparency bitmap or texture fill applied to the object
On the property bar, choose Bitmap or Texture from the Fill type list box. Then, click the Edit fill button, and modify the fill settings.
Add a node
Drag a color swatch from the color palette to the gradient arrow in the image window. Then type a value (0 to 100) in the Transparency box to specify the transparency for the node.
Delete a node
Right-click a node, and click Delete.
For information about editing fills, see Filling images.
Because the bitmap, texture, and flat gradient types affect an entire object, you cannot add nodes to customize their transparency values.
To make selected colors in an object transparent Back to Top
1.
Select an object.
2.
In the toolbox, click the Color transparency tool .
3.
Type a value in the Tolerance box on the property bar to specify the range of colors that will become transparent.
If you want to blend the surrounding colors with the transparent pixels, type a value in the Smoothing box. Higher values create a smoother transition.
4.
Click a color in the image window.
To blend an object Back to Top
1.
Select an object.
2.
In the Objects docker, click the flyout arrow and click Object properties.
3.
In the Object properties dialog box, click the General tab.
4.
Choose the channel you want to blend from the Blend list box.
5.
On the Active object graph and the Composite underlying graph, drag any of the following nodes:
Increasing maximum (top left node) — specifies the upper maximum grayscale value of the pixels in the object
Increasing minimum (bottom left node) — specifies the upper minimum grayscale value of the pixels in the object
Decreasing maximum (top right node) — specifies the lower maximum grayscale value of the pixels in the object
Decreasing minimum (bottom right node) — specifies the lower minimum grayscale value of the pixels in the object
You can also
Choose a blending method
Click a merge mode in the Merge box.
Adjust the opacity
Drag the Opacity slider.
The boxes to the right of the Blend list box display the grayscale and transparency values of the selected object’s pixels.
You can specify the grayscale values of pixels on a scale of 0 (black) to 255 (white), and the opacity of pixels on a scale of 0 (transparent) to 100 (opaque). Pixels in the active object that fall outside the specified range are hidden, so the pixels of the underlying object are visible.
