Neutral sampling points identified by using the advanced options of the Smart Photo Fix command
| To apply basic corrections with One Step Photo Fix |
| • | Choose Adjust |
| After a brief pause, several basic corrections are applied to your photo. |
If you are not satisfied with the changes made to your photo, choose Edit
Undo. Then, choose Adjust
Smart Photo Fix, and adjust the available settings. You can also try using other Adjust menu commands, such as Brightness and Contrast
Curves or Brightness and Contrast
Levels.
| To fine-tune basic corrections with Smart Photo Fix |
| 1 | Choose Adjust |
| 2 | Perform one or more tasks from the following table, and click OK. |
In the Brightness group box, type or set a value in the Overall, Shadows, and Highlights controls, or adjust their corresponding sliders.
Note: Positive settings brighten the photo, and negative settings darken the photo.
Type or set a value in the Saturation control, or adjust the slider.
Note: Positive settings make colors more vibrant; negative settings make colors less vibrant.
Type or set a value in the Focus control, or adjust the slider.
You can reset all settings to their initial values by clicking Suggest Settings, or to null settings by clicking the Reset to Default button
To use advanced settings of the Smart Photo Fix feature, mark the Advanced Options check box.
| To use the advanced options of Smart Photo Fix |
| 1 | In the Smart Photo Fix feature dialog box, mark the Advanced Options check box. |
| Additional controls appear in the dialog box. |
Mark the White Balance check box. The photo’s neutral areas (black, gray, and white) are identified in the Before pane.
Unmark the White Balance check box. Re-marking the check box restores the sampling points.
Drag the Black slider to the right, or specify a value in the control beside the slider.
Drag the White slider to the right, or specify a value in the control beside the slider.
Sampling points cannot be dragged or moved.
The histogram is for display only — you cannot drag or adjust any part it. The gray portion represents the original (Before) photo, and the red overlay portion reflects the adjustments. The black triangle moves in tandem with the Black slider, and the white triangle moves in tandem with the White slider. For more information about the Histogram, see Adjusting brightness, contrast, and clarity.
