By modifying the brush options, you can create your own brush tips to use with the painting tools. When you create a brush tip, all options selected for the brush are saved, including the brush shape, step, density, thickness, size, hardness, and rotation settings. You can also include the variance settings in creating a brush tip. The settings that you save can be applied to any tool that has a brush tip control in the Tool Options palette.
You can also make a selection, and then use the selection to create a custom brush with a width and height of up to 999 × 999 pixels.
In addition to brush tips, you can create brush presets. When you create a preset, all settings specified for a particular tool are saved, including all of the parameters and variance settings. The tool preset is available only when you select that particular tool.
Edit workspace
4
Click the Create Brush Tip button in the brush tip drop-list. |
You can also open the Create Brush Tip dialog box by choosing File
Export
Custom Brush.
To save the new brush in a folder other than the default Brushes folder, click Edit Paths in the Create Brush Tip dialog box. For more information on changing file locations, see Setting file locations.
Edit workspace
4
Click the Create Brush Tip from Selection button . |
Edit workspace
You can exclude any of the current brush settings from the preset by clicking the Save icon
associated with those settings in the Preset Includes list. A white "X" appears over the icon, indicating that this brush setting will not be saved with the preset.
