Corel PaintShop Pro resources include such items as scripts, picture tubes, patterns, gradients, displacement maps, and workspaces. The full listing of resources is displayed along the left side of the File Locations dialog box. Corel PaintShop Pro saves and searches for resources in several default folders on your computer. By changing File Locations preferences, you can change where Corel PaintShop Pro looks for and saves these resources. You can also control how plug-ins are used and which Web browsers are used to preview your images.
By default, all new files you create are saved in the appropriate subfolder in the ...Documents\Corel PaintShop Pro\16.0 folder. Most default program resources are stored in the appropriate folder in the path X:\Program Files(x86)\Corel\Corel PaintShop Pro X6 for 32-bit and X:\Program Files\Corel\Corel PaintShop Pro X6 (64-bit) for 64-bit, where "X" indicates the drive on which Corel PaintShop Pro is installed.
You can add or delete folders for Corel PaintShop Pro to store and retrieve the various resources. Deleting a folder means that Corel PaintShop Pro no longer looks in the folder for any items. The folder, however, is not deleted from your computer.
You can also change the file location for specific resources.
Edit workspace
Manage workspace
Choose File Preferences File Locations. |
5
In the Folder options group box, mark the Enable check box. |
7
Click OK to save your settings and return to Corel PaintShop Pro. |
You can open the File Locations dialog box by clicking the File Locations button
, which appears in many Corel PaintShop Pro dialog boxes.
Edit workspace
Manage workspace
From the File types list, select the resource file type for which you want to add locations. |
4
Click the Create a New Folder button and then enter the name for the new folder. |
5
Click OK to add the new folder to the list. |
6
Click OK to close the File Locations dialog box. |
The Cache and CMYK Profiles resource file types can have only one location. You can only change the file location from one folder to another. For more information on changing file locations, see Setting file locations.
Edit workspace
Manage workspace
From the File types list, select the resource file type that you want to delete file locations for. |
, which appears in many Corel PaintShop Pro dialog boxes, as well as in the Presets drop-list (located in the Tool Options palette) for tools.
