You can use the following text options to format your text:
| • | Font, Size, Units, and Font Style — let you choose a typeface, type size, units based on intended output (print or Web), and type style (bold, italic, underline, or strikethrough) |
| • | Alignment — lets you center multiple lines of text or align them on a left or right margin |
| • | Direction — lets you set the horizontal or vertical direction of the text |
| • | Kerning — lets you change the space between characters |
| • | Leading — lets you change the line spacing |
| • | Tracking — lets you set equal spacing between characters |
| • | Anti-alias — lets you smooth the edges of text characters |
You can also change the color of vector text. For information about using the Materials palette to choose colors for the text outline and fill, see Using the Materials palette.
How can you identify vector text?
| To change font attributes |
| 1 | On the Tools toolbar, choose the Text tool |
| 2 | Select the vector text characters you want to change by dragging over them. |
| Note: You can also select the entire text by pressing Ctrl + A. |
| 3 | On the Tool Options palette, perform a task from the following table, and click the Apply changes button |
Choose an option from the Font drop-list.
Choose an option from the Size drop-list.
From the Units drop-list, choose Points for print output or Pixels for Web output.
Click the Bold button
Click the Italic button
Click the Underline button
Click the Strikethrough button
| To change text alignment |
| 2 | Select the text object you want to align by dragging over it. |
| 3 | On the Tool Options palette, choose one of the following buttons: |
| 4 | On the Tool Options palette, click the Apply button |
| To set text direction |
| 2 | Select the text object you want to reposition by dragging over it. |
| Note: You can also select the entire block of text by pressing Ctrl + A. |
| 3 | On the Tool Options palette, choose one of the following options from the Direction drop-list: |
| • | Horizontal and Down |
| • | Vertical and Left |
| • | Vertical and Right |
| To change horizontal spacing between characters |
| 2 | Select the text characters whose spacing you want to change by dragging over them. |
| 3 | On the Tool Options palette, type or set a value in the Kerning control. |
| Positive values increase the spacing; negative values decrease the spacing. |
You can use the built-in kerning values for the current font by marking the Auto Kern check box.
| To change vertical spacing between lines of text |
| 2 | Select the text lines whose spacing you want to adjust by dragging over them. |
| Note: You can also select the entire block or text by pressing Ctrl + A. |
| 3 | On the Tool Options palette, type or set a value in the Leading control. |
| To set equal spacing between characters |
| 2 | Select the text characters whose spacing you want to adjust by dragging over them. |
| 3 | On the Tool Options palette, type or set a value in the Tracking control. |
| To smooth jagged edges in text |
| 2 | Select the text object whose edges you want to adjust by dragging over it. |
| 3 | On the Tool Options palette, choose an option from the Anti‑alias drop-list: |
| • | Off — applies no anti-aliasing (edges appear jagged) |
| • | Sharp — applies a slight degree of edge smoothing |
| • | Smooth — applies a stronger degree of edge smoothing |
