You can import custom brushes or create your own. For information about creating custom brushes, see Creating brush tips and presets.
| To import a custom brush |
| 1 | Choose File |
| The Import Custom Brush dialog box appears. |
| 2 | Click Open. |
| 3 | In the Open dialog box, navigate to the brush file that you want to import, and click Open. |
| 4 | In the Import Custom Brush dialog box, select the custom brushes that you want to import, and click Add. |
| If you want to import multiple brushes, click Add All. |
| 5 | Click OK to import the custom brushes. |
| To share brush tips |
| 1 | Navigate to ...Documents\Corel PaintShop Pro\16.0\Brushes. |
| Navigate to the folder in which you saved your custom brushes if it is different from the default Brushes folder. |
| 2 | Share the brush files (those with .PspBrush or .PspScript extensions) — for example, by attaching them to an e-mail message. |
| The recipient should save the brush files to ...Documents\Corel PaintShop Pro\16.0\Brushes, or to the folder that contains custom brushes. |
