You can delete, rename, copy, and move resources. You can also create your own resource categories.
| To access the Resource Manager dialog box |
| • | Click a Presets control, and click the Resource Manager button |
| To delete a resource |
| 1 | Click a Presets control, and click the Resource Manager button |
| 2 | If necessary, from the Category drop-list choose the category where the resource resides. |
| 3 | Click the resource from the list. |
| 4 | Click Delete. |
| To rename a resource |
| 4 | Click Rename. |
| The Rename Resource dialog box appears. |
| 5 | Type the new name for the resource, and click OK. |
| To copy a resource to another location |
| 4 | Click Copy. |
| The Save As dialog box appears. |
| Note: At this point, you can also rename the file by typing a new name in the File Name field. |
| 5 | Navigate to the folder where you want to move the resource and click Save. |
| Note: You cannot copy a resource without renaming it to a folder currently being scanned using the File Locations dialog box. |
| To move a resource to another location |
| 4 | Click Move. |
| The Browse for Folder dialog box appears. |
| 5 | Navigate to the folder where you want to move the resource, and then click OK. |
| To create a resource category |
| 1 | Choose File |
| The File Locations dialog box appears. |
| 2 | In the File types list on the left side of the dialog box, click the resource for which you want to create a new category folder. |
| 3 | In the folders list, click the folder under which the custom category subfolder will reside. |
| 4 | In the Folder Options group box, mark the Enable and Use sub folders check boxes. |
| 5 | Click Create Sub Folder. |
| The Enter Name dialog box appears. |
| 6 | Type a name for the custom category subfolder, and click OK to close the Enter Name dialog box. |
| 7 | Click OK. |
