The Arrow tool lets you modify a hotspot area.
The Mover tool lets you move a hotspot area.
The Polygon tool lets you create an irregular-shaped hotspot area.
The Rectangle tool lets you create a square or rectangular hotspot area.
The Circle tool lets you create a circular or elliptical hotspot area.
The Delete tool lets you delete a hotspot area.
The Pan tool lets you drag the image in the preview to view hidden areas of the image.
After you have created the map areas (or regions), you can assign URLs, alternate text, and targets.
To create and save a map area |
1 | Choose File ![]() ![]() |
The Image Mapper dialog box appears. |
2 | Choose one of the following tools and draw in the preview area to create a hotspot: |
• | Rectangle tool ![]() |
• | Circle tool ![]() |
• | Polygon tool ![]() |
3 | In the URL drop-list, type the address of the Web page to which you want to link. |
If you want to select addresses already used in the image, click the arrow in the box and select the address you want from the URL drop-list. |
If you do not want to link to a Web page, type #. |
4 | In the Alt text box, type the text that appears if the image does not load or if the user has images disabled in the Web browser. |
5 | Choose one of the following target frame options from the Target drop-list: |
• | _blank — loads the linked page in a new browser window |
• | _parent — loads the linked page in the parent frameset of the link. If the link is not in a nested frame, the image loads in the full browser window. |
• | _self — loads the linked page in the same frame as the link |
• | _top — loads the linked page in the full browser window and removes all frames |
6 | Click Save. |
The HTML Save As dialog box appears. |
7 | Navigate to the folder where you want to save the HTML code, and click Save. |
The Image Map Save As dialog box appears. |
8 | Navigate to the folder where you want to save the image and click Save. |
Click the Arrow tool
Click the Arrow tool, click the shape to select it, and hover over one of the green points that appear until the cursor changes to a four-point arrow. Drag the point to a new position.
Click the Move tool
Click the Delete tool
Click Clear.
Click the Preview in browser button
Click Save to Clipboard to open the HTML Destination Folder dialog box, navigate to the folder where the HTML file is saved, and click OK to save the slice settings. Then, open the HTML file, place the cursor where you want to insert the HTML slice code, and press Ctrl + V.
Click Rollover Creator. For more information about creating image rollovers, see Creating image rollovers.
To set map preferences |
1 | In the Image Mapper dialog box, click Preferences. |
The Map Preferences dialog box appears. |
2 | Click the Active tile border color box, and choose a color. |
3 | Click the Inactive tile border color box, and choose a color. |
4 | In the Maximum history list size control, set or type the number of entries listed in the URL and Alt text drop-lists in the Cell Properties group box in the Image Mapper dialog box. |
5 | Click OK. |
To save map settings |
1 | Click Save Settings. |
The Save Map Settings dialog box appears. |
2 | Navigate to the folder in which you want to save the settings file. |
3 | Type a name for the file and click Save. |
The file is saved in the JMD format. |
To load map settings |
1 | Open the image in which you want to load map settings. |
2 | Choose File ![]() ![]() |
3 | Click Load Settings. |
The Load Map Settings dialog box appears. |
4 | Navigate to and select the JMD file you want to load. |
5 | Click Open. |
