You can rotate an image in Corel PaintShop Pro.
You can also rotate an image to any angle by specifying a degree of rotation or by rotating it interactively on the canvas. For information about rotating an image to straighten it according to reference points within the image, such as the horizon, see Straightening images.
| To rotate an image |
| • | Select an image, and perform a task from the following table. |
Choose Image
On the Tools toolbar, choose the Pick tool
You can also rotate an image by clicking the Rotate Right
or Rotate Left
button on the Standard toolbar.
If you want to change the center of rotation before you interactively rotate the image, hold down Ctrl, and drag the rotation pivot point (the circle at the center of the image) to a new position.
