The Arrow tool lets you make a cell active or move its borders.
The Grid tool lets you create a grid of evenly spaced cells, either over the entire image or within another cell.
The Slicer tool lets you create a horizontal or vertical line.
The Delete tool lets you delete slice lines.
The Pan tool lets you drag the image in the preview to view hidden areas of the image.
Assigning sliced cell properties
You can select colors for the border lines of the active and inactive areas.
Saving and loading slice settings
You can save slices to a folder on your hard drive so that you can reuse or edit them.
To slice an image into cells |
1 | Choose File ![]() ![]() |
The Image Slicer dialog box appears. |
2 | Choose the Slice tool ![]() |
Note: To create a vertical line, drag vertically; to create a horizontal line, drag horizontally. |
3 | Choose the Arrow tool ![]() |
The cell boundary information is displayed in the lower portion of the Cell Properties group box. |
4 | In the URL drop-list, type the address of the Web page where you want the cell to appear. |
If you want to select addresses already used in the image, select the address you want from the URL drop-list. |
5 | In the Alt text box, type text that the browser can display while the cell is downloading. |
6 | Choose one of the following target frames or window options from the Target drop-list: |
• | _blank — loads the linked page in a new browser window |
• | _parent — loads the linked page in the parent window or frameset of the link. If the link is not in a nested frame, the image loads in the full browser window. |
• | _self — loads the linked page in the same window or frame as the link |
• | _top — loads the linked page in the full browser window and removes all frames |
7 | Click Save. |
The HTML Save As dialog box appears. |
8 | Navigate to the folder where you want to save the HTML code and click Save. |
Click the Grid tool
Click the Arrow tool
Click the Delete tool
Click the cell with the Arrow tool, and unmark the Include cell in table check box.
Click Save to Clipboard to open the HTML Destination Folder dialog box, navigate to the folder where the HTML file is saved, and click OK to save the slice settings.
Click Rollover Creator. For more information about creating image rollovers, see Creating image rollovers.
To set slice preferences |
1 | In the Image Slicer dialog box, click Preferences. |
2 | Click the Active tile border color color box, and choose a color. |
3 | Click the Inactive tile border color color box, and choose a color. |
4 | In the Maximum history list size control, type or set the number of entries listed in the URL and Alt text drop-lists in the Cell Properties group box in the Image Slicer dialog box. |
5 | Click OK. |
If you want to be prompted for a file location and name for your slices when you save the HTML code, mark the Prompt for image folder on Save or Save As check box.
To save slice settings |
1 | In the Image Slicer dialog box, click Save Settings. |
The Save Slice Settings dialog box appears. |
2 | Navigate to the folder in which you want to save the settings file. |
3 | Type a name for the file and click Save. |
The file is saved in the JSD format. |
To load slice settings |
1 | In the Image Slicer dialog box, click Load Settings. |
The Load Slice Settings dialog box appears. |
2 | Select the JSD file you want to load, and click Open. |
