The Pick tool lets you transform images interactively in the following ways:
| • | Scaling resizes an image horizontally, vertically, or proportionally. |
| • | Shearing skews an image vertically or horizontally. |
| • | Distorting an image stretches or contracts it in any direction. |
| • | Applying perspective to an image corrects the perspective or applies a false perspective. For information about correcting image perspective, see Correcting photographic perspective. |
| • | Rotating an image moves it around a pivot point. For information about rotating images, see Rotating images. |
Setting scaling and transformation options
| • | Pivot X, Pivot Y — sets the X and Y coordinates of the rotation pivot point |
| • | Position X, Position Y — sets the X and Y coordinates of the top left corner handle |
| • | Scale X (%), Scale Y (%) — sets the percentage of change for the horizontal (X) and vertical (Y) resizing |
| • | Shear — sets the offset of a side. Positive values shear to the right, and negative values shear to the left. |
| • | Angle — sets the rotation around the pivot point. The image is rotated clockwise, from 0 to 360 degrees. |
| • | Reset Rectangle button |
| • | Perspective X, Perspective Y — adjusts the perspective of the deformation |
Important! The Pick tool works on grayscale and 16 million– color images only. For more information about increasing the color depth of an image, see Increasing the color depth of an image. For more information about deforming vector objects or text, see Sizing, shaping, and rotating vector objects or Sizing and transforming text.
| To scale or transform a selection, layer, or image |
| 1 | Choose a selection, layer, or image by clicking its name on the Layers palette. |
| 2 | On the Tools toolbar, choose the Pick tool |
| A bounding box with handles appears. |
| 3 | Perform one or more tasks from the following table. |
Hold down Ctrl, and drag a corner handle horizontally or vertically.
Hold down Ctrl + Shift, and drag a corner handle horizontally or vertically.
Hold down Shift, and drag a side handle.
Hold down Ctrl + Shift, and drag a side handle.
By default, you must hold down Ctrl + Shift to distort an image. To distort an image without holding down keys, choose a different Mode setting on the Tool Options palette. The Scale mode is the default setting, so you must hold down a key or keys. The Shear mode lets you shear without holding down Shift. The Perspective mode lets you change perspective without holding down Ctrl. The Free mode lets you distort without holding down Ctrl + Shift.
When the Pick tool is active, you can scale and transform precisely by setting values in any of the boxes on the Tool Options palette.
