You can use the Picture Tube tool to paint with a collection of objects. For example, you can add butterflies and beetles to a picnic setting or frame a picture with flowers. You can use one of the picture tubes included with Corel PaintShop Pro or create your own.
The Picture Tube tool lets you apply various preset images to your photos to create unique effects.
Picture tubes are PspTube files. Each picture tube file is made up of a series of images arranged in rows and columns, called cells. Picture tubes may have any number of cells. As you paint with the Picture Tube tool, Corel PaintShop Pro paints one image from the picture tube after another. Many picture tubes create discrete images (such as zoo animals), and others create the effect of a continuous image (such as grass).
Each picture tube file contains a series of images.
To make picture tube elements easier to edit, it is helpful to paint them on a separate layer.
Important! You cannot use the Picture Tube tool on vector layers.
Where can I get more picture tubes?
You can create your own picture tubes. You can use picture tubes from a previous version of the application. For more information, see To use picture tubes from previous versions of the application.
You can also download free picture tubes from the Web by checking the Corel website (www.corel.com) or by using the keyword phrase "free picture tubes" in an online search engine.
Important! This tool works only on raster layers in grayscale and 16 million–color images. Using this tool on a 256-color or lower raster image automatically promotes the image to the appropriate color depth. To convert a vector layer to a raster layer, choose Layers
Convert to Raster Layer. For more information about increasing the color depth of an image, see Increasing the color depth of an image.
Picture Tube settings
When you click the Settings button
on the Tool Options palette, the Picture Tube Settings dialog box appears. You can use this dialog box to update the current Tool Options palette settings and to modify the look of the current picture tube. However, you can also make the settings permanent by marking the Save as default for this Picture Tube option.
Cell arrangement — The Cells across and Cells down fields display the current cell layout of the tube. The ranges for these values depend on how the tube was created. The Total cells field shows the product of multiplying the Cells across value by the Cells down value. |
Placement options — Modifying any of these settings updates the corresponding setting on the Tool Options palette. Note that the Scale setting is only available for some picture tubes. |
Save as default for this Picture Tube — Mark this check box if you want to save any modifications made in the Picture Tube Settings dialog box. If you do not mark this check box, the changes affect only the current use of the picture tube. |
Edit workspace
Scale — determines the percentage (10% to 250%) for reducing or enlarging each image in the picture tube and scaling the step |
Step — determines the distance in pixels (1 to 500) between the centers of each picture tube cell that you paint |
Placement mode — determines how the images are placed. Choose Continuous to space the images evenly by step size, or choose Random to randomly space the images, with intervals ranging from 1 pixel to the step size. |
Selection mode — determines how Corel PaintShop Pro selects images from the cells within the picture tube file. Angular selects images based on the direction you drag; Incremental selects images one by one from top left to bottom right; Pressure selects images based on the pressure you apply on a pressure-sensitive tablet; Random selects images randomly; and Velocity selects images based on the speed with which you drag. |
You can make further changes to the behavior of the current picture tube by clicking the Settings button
on the Tool Options palette and adjusting settings in the Picture Tube Settings dialog box.
Edit workspace
Choose View Change Grid, Guide & Snap Properties. |
In the Current image settings group box, type or set the Horizontal grids and Vertical grids, and click OK. |
Image Dimensions — sets a width and height (in pixels) that are multiples of the horizontal and vertical grid spacing. The width and height of the image determine the total number of cells in the image. For example, if the grid spacing is 100 pixels, you can create an image that is 400 pixels wide by 300 pixels high. These dimensions would produce 12 cells (four across and three down). |
Image Characteristics — Choose Raster Background as the layer type, 8 bits/channel or 16 bits/channel as the Color depth, and mark the Transparent check box. |
8
Choose File Export Picture Tube. |
Cell arrangement — Enter the number of cells across and down. Set these fields to match your arrangement of images in step 7. The Total cells field should match the number of images you placed in the tube file. |
Placement options — Choose the default options for this picture tube. You can change these options when you apply the picture tube. |
Tube name — Enter the filename of the tube. The extension .PspTube is automatically added to the filename. |
If you want to use one image as a paint brush, export the image as a picture tube. Use a cell arrangement of one cell across by one cell down. The image must contain one raster layer that is not the background. To promote the background to a layer, choose Layers
Promote Background Layer. Choose the Picture Tube tool, and select the new picture tube you created.
Edit workspace
Choose the Picture Tube tool from the Tools toolbar. |
