The Manage workspace makes it easy for you to preview and organize photos by using thumbnails.
For a larger view of photos, use Preview mode, zoom in and out on thumbnails, or use Quick Review to view photos in full-screen mode. You can sort thumbnails by criteria such as name, rating, or date. You can also rotate photos by using thumbnails, or delete and rename the files.
For multi-image shooting, you can use Auto Group and RAW/JPG Pairs to group and view thumbnails according to bracketing settings or JPEG+RAW file pairs.
Thumbnails let you edit multiple photos by using Capture editing and Apply editing. For more information, see Capturing and applying edits to multiple photos.
In addition, you can select one or more RAW file thumbnails to convert the files to another format. For more information, see Converting RAW photos to another file format.
The Zoom slider is not available when the Manage workspace is in Preview mode.
Manage workspace
Date Created - Newest — sorts thumbnails, from newest to oldest, by the date on which the photo was taken |
Date Created - Oldest — sorts thumbnails, from oldest to newest, by the date on which the photo was taken |
Date Modified — sorts thumbnails by the date on which the image was last modified |
Folder — sorts thumbnails alphabetically by folder name |
Filename — sorts thumbnails alphabetically by filename (image name) |
Rating — sorts thumbnails by image rating |
File Format — sorts thumbnails alphabetically by filename extension (for example, .psp image, .jpg, or .tif) |
File Size — sorts thumbnails by the file size (in kilobytes) from smallest to largest |
Place — sorts thumbnails by the location that is associated with the photo |
OFF — shows thumbnails for both the RAW and JPEG versions of the files. |
If you delete a thumbnail when the RAW/JPG Pairs option is turned on, both versions of the files are sent to the Recycle Bin.
Manage workspace
Manage workspace
Click the Play button below the Preview area. |
Example of a video thumbnail
Corel PaintShop Pro supports the video formats that are supported by your system.
You can extract a frame from a video and save it as an image by clicking the Pause button to stop the video on the frame that you want to save, and clicking the Capture button
Manage workspace
Rotate Left — rotates thumbnails 90 degrees counterclockwise |
You can also right-click a thumbnail and choose Rotate Right or Rotate Left from the context menu.
Click Yes to send the images to the Recycle Bin. |
You can also delete photos by selecting thumbnails, right-clicking a selected thumbnail, and clicking Delete in the context menu.
Manage workspace
The Organizer palette is available in the Adjust workspace, so you can access other photos.
You can also start the Adjust workspace by right-clicking one or more selected thumbnails and choosing Adjust Photo.
Manage workspace
You can also start the Edit workspace by right-clicking one or more selected thumbnails and clicking Edit Photo in the context menu.
