Drawing lines
You can draw straight lines, freeform lines, and line segments. You can edit the nodes in a line to create curves.
You can also adjust the line options of existing vector objects.
To draw a line segment Back to Top
Edit workspace
Mark the Show Nodes check box.
Mark the Anti-alias check box.
Select an option from the Join drop-list. If you select Miter Join, you can type or set a value in the Miter limit control to set the degree of pointedness.
Hold down Shift while dragging.
Mark the Connect Segments check box.
You can save your settings in the Tool Options palette settings for subsequent use. For more information about saving settings as presets, see Using and creating presets.
To draw a curved or straight line Back to Top
Edit workspace
To draw a free-form line Back to Top
Edit workspace
To draw line segments Back to Top
Edit workspace
