Drawing rectangles and squares
You can draw squares and rectangles.
To draw a rectangle or square Back to Top
Edit workspace
Type or set values in the Horizontal Radius and Vertical Radius controls.
Choose an option from the Line Style drop-list, and type or set a value in the Width control beside the drop-list.
Mark the Anti-alias check box.
Choose an option from the Join drop-list. If you choose Miter join, you can also type or set a value in the Miter Limit control.
Mark the Show nodes check box. Type or set values in the Width and Height controls.
Mark the Show nodes check box. Type or set values in the Left and Top controls.
You can save your settings as a preset. For more information, see Using and creating presets.
