Editing scripts in Corel PaintShop Pro
You can edit scripts using the Corel PaintShop Pro user interface, or by editing the script’s Python code in a text editor application. For more information about editing scripts, see Editing scripts using a text-editing application.
To edit the currently selected script Back to Top
Edit workspace
Click Text Editor. The text editor assigned in the File Locations dialog box opens the script. Unless you specify another application, the default editor is Notepad.
If the script format is unreadable, or if the script was created and edited manually in a text editor, the Corel PaintShop Pro Script Editor cannot open the script. Instead, the script opens in the default text editor that is specified in the File Locations dialog box. For more information, see Editing scripts using a text-editing application.
If the script you want to edit is not in the Select Script drop-list, choose File Script Edit and choose the folder where the script is saved. When you open the script, its information appears in the Script Editor dialog box.
To set a playback mode for a script action or command Back to Top
Edit workspace
