| • | Face recognition — analyzes facial characteristics and uses reference photos to build a list of possible matches. People with similar characteristics are sorted into groups, making it easier for you to look through your photos and identify people. You can move photos between groups until all photos of the same person are in one group, and then type a name for the group to automatically tag all photos in the group with the name of that person. |
| • | Manual tagging — lets you tag people manually in your photos. You can add multiple tags to the same photo, or tag objects or other areas of the photo with the names of people, to make sure that they are notified when the photo is uploaded. |
Importing your friends list from sharing sites
| To sort photos by people |
| 1 | In the Navigation palette, click the Collections tab. |
| 2 | Navigate to the folder containing the images that you want to sort. |
| 3 | In the Organizer palette, click the Find People button |
| • | Scan selected photos |
| • | Scan current folder |
| • | Scan subfolders |
| If no photos are selected, face recognition is applied to the whole folder. |
| After you run face recognition, the photos are sorted into groups of people and placed in a folder called Unnamed. |
| 4 | If the Manage workspace is not in Thumbnail mode, click the Thumbnail Mode button |
| 5 | Click in the title bar of a group and type a name for the group. |
| All photos in the group are tagged with the name. |
In the Navigation palette, right-click the folder name, and choose Delete Group. The group name is deleted, the tags are removed from the photos, and the photos are moved back to the Unnamed folder.
Right-click the photo, choose Move Person, and choose a name from the list. You can also drag a photo to another folder in the Navigation palette.
Right-click the photo, choose Move to New Person, and type a name for the new group. The photo is removed from the current group and placed in the new group.
Right-click the photo, and choose Remove Person from Group. You can also drag a photo from a named group to the Unnamed folder in the Navigation palette.
Right-click the photo, and click Ignore Person. In the Unnamed group, you can also click the Delete button in the upper-right corner of the photo.
Select the Unnamed folder in the Navigation palette, and click Ignored. Select the photo, and click Do Not Detect.
Click the icon for the sharing site in the Link tags area, and choose a name from the list. Note: The friends list from the site must be imported first (see To import a friends list from a sharing site).
| To import a friends list from a sharing site |
| 1 | In the Navigation palette, click the Collections tab, and click a name in the People list. |
| 2 | In the Link tags area, click the icon that corresponds to the sharing site from which you want to import your friends list. |
| If you are not currently logged into the sharing site, you’ll be asked to log in and allow Corel PaintShop Pro to access the site. |
| To tag people manually |
| 1 | In Preview mode, select the photo that you want to tag. |
| 2 | Under the People tab in the Info palette, click Tag Person. |
| A square frame appears in the center of the photo in the preview window. |
| 3 | Click in the Who is this? box. |
| A name picker appears, showing a local name list, as well as the contacts from sharing sites that you have imported. |
| 4 | Do one of the following: |
| • | Type a name in the box, and click Add New Person. |
| • | Choose a name from the local list of names. |
| • | Click a sharing site tab, and choose a name from the list. |
Point to the frame, click the button
Point to the frame, and click the Delete button
In the name picker, click a name in the local list, and then click the corresponding name in one or more of the sharing site lists. Click Save to tag the photo and link the local and sharing site name tags.
In the name picker, click Update Contacts.
