Formatting text
The text formatting options in Corel PaintShop Pro let you control the appearance of text. You can set these options when you create vector, raster, or selection text. If you create vector text, you can reformat the text at any time by changing your text formatting settings. You cannot change the characters or formatting of raster text. You can modify raster text only by using the Pick tool.
You can use the following text options to format your text:
You can also change the color of vector text. For information about using the Materials palette to choose colors for the text outline and fill, see Using the Materials palette.
How can you identify vector text?
Vector text, like other vector objects, can be identified by the vector icon that appears next to the text in the Layers palette.
To change font attributes Back to Top
Edit workspace
From the Units drop-list, choose Points for print output or Pixels for Web output.
Click the Bold button .
Click the Italic button .
Click the Underline button .
Click the Strikethrough button .
To change text alignment Back to Top
Edit workspace
To set text direction Back to Top
Edit workspace
To change horizontal spacing between characters Back to Top
Edit workspace
Kerning values are expressed as 1 being equal to one em space — the width of capital letter M for a given font and font size.
You can use the built-in kerning values for the current font by marking the Auto Kern check box.
To change vertical spacing between lines of text Back to Top
Edit workspace
To set equal spacing between characters Back to Top
Edit workspace
To smooth jagged edges in text Back to Top
Edit workspace
Anti-aliasing may increase the number of colors in an image, which may cause stray colors to appear along the edges of text. Anti-aliasing may also make it difficult to reduce the file size and to maintain image quality.
