You can also resize and reshape vector text by editing its nodes and contours. For more information, see Working with nodes.
1 | Open a copy of the image. |
2 | On the Tools toolbar, choose the Text tool ![]() |
3 | On the Tool Options palette, choose Selection from the Create As drop-list, and set the other text controls. |
4 | In the image window, click where you want to create the text selection, and type the text. |
5 | On the Tool Options palette, click the Apply changes button ![]() |
6 | Copy the text selection to a new image. |
To resize and transform text |
1 | On the Layers palette, choose a layer. |
2 | On the Tools toolbar, choose the Pick tool ![]() |
A bounding box with handles appears on the selection or the layer. |
3 | Drag a corner handle to resize the text. |
If you want to change the current proportions, right-click and drag a handle. |
4 | Perform any of the actions in the following table to transform the text. |
Hold down Ctrl and drag a corner handle horizontally or vertically.
Hold down Shift and drag a corner handle.
Hold down Shift while dragging a side handle.
Hold down Ctrl and Shift while dragging a handle.
