Sizing, shaping, and rotating vector objects
You can transform vector objects and vector text interactively. For example, you can drag the handles on a bounding box to size, shape, or rotate objects. You can also transform vector objects by editing their nodes. For more information, see Working with nodes.
You can also size vector object to make them the same width, height, or both.
To size and shape a vector object Back to Top
Edit workspace
Hold down Shift, and drag a corner handle.
Hold down Shift, and drag a side handle.
Hold down Ctrl + Shift, and drag a handle.
To rotate vector objects Back to Top
Edit workspace
To change the center of rotation, hold down Ctrl, and drag the rotation pivot point to a new location.
To make vector objects the same size Back to Top
Edit workspace
To change the object’s proportions while resizing, select the object with the Pick tool , and then right-click and drag a corner handle.
