Undoing and redoing actions
You can undo single or multiple actions as you edit an image. For example, you can undo brushstrokes, color adjustments, or effects that you have applied to the image. You can also redo single or multiple actions to reapply commands that you have undone.
You can also revert to the last saved version of the image.
The History palette lets you undo and redo actions selectively, regardless of their sequence.
Important! The Undo control does not undo the following actions: renaming files, saving files, opening and closing files, emptying the Clipboard, making changes that are program-wide and not specific to the current image (such as changes to color settings and preferences), or using commands that do not change the image pixels (such as zooming or scrolling).
Undo and redo controls on the History palette
You can undo multiple actions, as well as specific actions, by using the History palette. The History palette lists all actions performed on the active image. The most recent action is at the top of the list, and the first action performed is at the bottom of the list. Unlike the Undo and Redo commands, the History palette lets you undo or redo actions selectively, regardless of their sequence.
By default, the History palette lists the 250 most recently executed commands on the active image. You can set the Undo preferences and specify a higher or lower number of commands.
The table below lists the Undo/Redo controls on the History palette.
Undo to Here
Redo to Here
Undo Selected
Undoes a selected action. Clicking this button is equivalent to holding down Ctrl and clicking an item’s eye icon. Note: Undoing a selected action may interfere with subsequent actions and produce unintended results.
Redo Selected
Clear Selectively Undone Commands
Show Non-Undoable Commands
Empty Command History
For more information about the History palette, To undo and redo actions by using the History palette.
To undo an action Back to Top
Edit workspace
The Undo command undoes multiple actions in the order in which they were performed. To undo actions selectively, you can use the History palette.
If the action cannot be undone, the Undo command is unavailable.
You can also undo an action by clicking the Undo button on the Standard toolbar, or by pressing Ctrl + Z.
To redo an action Back to Top
Edit workspace
The Redo command redoes multiple actions in the order in which they were undone. To redo actions selectively, you can use the History palette.
Only actions that have been undone can be redone.
You can also redo an action by clicking the Redo button on the Standard toolbar, or by pressing Ctrl + Alt + Z.
To revert to the last saved version of an image Back to Top
Edit workspace
To undo and redo actions by using the History palette Back to Top
Edit workspace
Click the Undo/Redo button for the selected action, or click the Undo to Here button . The undone actions are denoted by a blank box .
Click the Undo/Redo button for the selected action, or click the Redo to Here button . The selected action and all preceding actions are redone and no longer appear as blank icons. Note that selectively undone actions (denoted with a gray X) that precede the action you clicked are not redone. These actions can be redone only with the Redo Selected command.
Hold down Ctrl, and click the Undo/Redo button for the selected action, or click the Undo Selected button . Selectively undone actions are denoted by a gray X .
Hold down Ctrl, and click the Undo/Redo button for the selected action, or click the Redo Selected button .
To set Undo preferences Back to Top
Edit workspace
Non-undoable steps cannot be undone or redone. However, they can be reapplied to the current image or to other open images, saved to a Quickscript or to a regular PspScript file, or copied to the Clipboard.
