Filling an area with a sampled image
You can apply a transformed sample by filling, instead of using a brush. Filling allows you to cover a large area evenly, without much effort. Filling is supported only when you use perspective or bilinear sampling, with or without tiling.
To apply a transformed sample as a fill, you need to set both sample source and destination reference points, as you would when applying a sample with a brush. For information, see Multi-point cloning.
If you want to save the sample source reference area as a pattern for future use, you can capture the pattern. For more information, see Creating and editing patterns.
To fill with a transformed source image
Back to Top
1 In the Brush Selector, choose the Painter 2015 brushes library from the Brush library list box.
2 Click the Cloners brush category, and click a brush variant that allows you to select four sample source and four destination points:
• XPerspective 4P
• XPerspective Tiling 4P
• XBilinear 4P
3 In the Clone Color panel (Window Brush Controls Panels Brush Media Clone Color), enable the Clone Color check box.
4 Do one of the following:
• If you chose the XPerspective 4P or XPerspective Tiling 4P variant, choose Perspective from the Clone Type list box.
• If you chose the XBilinear 4P variant, choose Bilinear from the Clone Type list box.
5 Hold down Option (macOS) or Alt (Windows), and click to set the four sample source reference points.
6 Hold down Option + Shift (macOS) or Alt + Shift (Windows), and click to set the four destination reference points.
7 Click the Paint Bucket tool in the toolbox.
8 Choose Source Image from the Fill list box on the property bar.
9 Click in the destination area to apply the fill.
You can disable offset sampling by clicking the Clone Color button in the Color panel or by choosing a non-Cloner brush variant in the Brush Selector.
The destination points determine where the transformation occurs.
You can use transformed clone information to make a brick pattern become a steep wall.
