General controls: Stroke types
The Stroke Type determines how a brushstroke applies media. Corel Painter brushes use one of the following stroke types.
The
Single stroke type draws one dab path that corresponds exactly to your brushstroke.
You can use
Static Bristle,
Captured, or one of the bristly rendered dab types (such as
Camel Hair) with the
Single stroke type to create the effect of multiple bristles.
The Single stroke type has one dab path.
The
Multi stroke type draws a set of randomly distributed dab paths, positioned around the brushstroke you make. These dabs leave dab paths that are not parallel and might overlap. The
Multi stroke type may produce different results each time you use it. For more information, see
Multi controls.
Increasing the
Stroke Jitter value in the
Stroke Jitter panel spreads out the strokes in a multi-stroke brush.
Increasing the amount of bristles can increase the density of the brushstroke. For more information, see
Multi controls.
Multi-stroke brushes are computed before you apply them, therefore, the computing process can delay their appearance on the canvas. Because of this delay, multi-stroke brushes work best when you apply short, controlled strokes.
The Multi stroke type draws a set of randomly distributed dab paths.
The
Rake stroke type draws a set of evenly distributed dab paths. The several dab paths in a rake brushstroke are parallel. You can control all other aspects of the stroke by using settings in the
Rake brush control panel.
Each bristle in a
Rake brush can have a different color. Increasing Color Variability in Corel Painter causes bristles to be colored differently.
A Rake stroke is composed of evenly distributed dab paths.
The
Hose stroke type applies only to the
Image Hose. It’s a single stroke composed of the current Image Hose Nozzle file. For more information about the
Image Hose and Nozzle files, see
Image hose.
The Hose stroke type uses the current Nozzle file as media.
The
Glazing stroke type draws brushstrokes with smooth opacity build-up from the beginning of the mark to the end. The paint that each dab deposits on the canvas is temporarily added to an invisible layer, and then the layer is dropped down onto the canvas.
In a Glazing stroke type, opacity builds up gradually from a minimum to a maximum along a brushstroke.
To choose a stroke type
Choose
Window
Brush Control Panels
General.
Choose a stroke type from the
Stroke Type list box.
If a stroke type is not available (appears grayed out), it’s not supported by the currently selected brush variant and dab type.
