Cloning with Thick Paint brushes
Turn a Thick Paint brush into a cloner by clicking the Clone Color button
in the Color panel (Window
Color Panels
Color Panel (Full View)) and start painting. For more information about cloning, see Image cloning and sampling. If you are not satisfied with the appearance of the brushstrokes, try the following:
Increase the brush size.
Increase the droplet radius. Select a Thick Paint brush variant. On the property bar, click the
Shape flyout button
![](../Shared_graphics/thick_paint_shape_panel.svg)
, and in the
Droplets area, move the
Radius slider to the right to increase the size of the paint droplets.
Decrease the brush density. Select a Thick Paint brush variant. Click the
Shape flyout button
on the property bar, and move the
Brush Density slider to the left in small amounts (for example, minus 2%) to reduce the number of bristles in the brush.
Blur the clone source by painting with brushes from the
Blenders category or by applying a Focus effect (
Effects
Focus), such as
Depth of Field,
Glass Distortion,
Motion Blur, Zoom Blur or
Woodcut (Click
Effects
Surface Control
Woodcut. Disable the
Output black check box. Move the
Color edge slider to the right). To blur the clone source, in the
Clone Source panel, enable the
Show Source Image check box. Click in the
Source Image window, and click
OK. Blur the source image by using a blender brush or an effect. Once you are done, click the clone document, and enable the
Create New option in the dialog box that appears.
