Using Dynamic Speckles with Particle brushes
Some Particle brushes can be used with dynamic speckles to create thicker, more pronounced brushstrokes. Dynamic speckles generate a continuous brushstroke from discrete spots of color or speckles. The speckles in the brushstroke are truly dynamic — they are generated as you paint.
To use dynamic speckles, you must choose a Dynamic Speckle dab type from the General brush control panel (Window Brush Control Panels General). For more information, see Dynamic Speckles controls.
A Flow Particle brushstroke (left) and a Dynamic Speckle Flow Particle brushstroke (right)
A Gravity Particle brushstroke (left) and a Dynamic Speckle Gravity Particle brushstroke (right)
A Spring Particle brushstroke (left) and a Dynamic Speckle Spring Particle brushstroke (right)
