| • | To modify surface lighting to adjust depth |
| • | To adjust ambient lighting |
| • | To add, remove, or modify a directional light source |
| • | To adjust the intensity and brightness of directional light |
In addition, you can use ambient lighting or directional lighting.
You can modify the impasto effect by increasing the appearance of depth.
Adjusting the appearance of depth
To change the depth of individual brushstrokes, you can vary stylus settings or build up media. For more information, see Blending impasto with other layers.
Setting directional light sources
When you disable the Simple lighting option, the lighting sphere appears with a single light indicator. You can then add more light sources and change their position.
The image above uses two different colored light sources.
You can also adjust the intensity and brightness of directional light.
| 1 | Choose Canvas |
| 2 | In the Appearance of Depth area, adjust any of the following sliders: |
| • | Amount — increases or decreases the visibility of brush striations in brushstrokes. The highest value displays more striations to create the illusion of more texture and increased depth, whereas the lowest value displays fewer striations to create the illusion of smooth texture without depth. |
| • | Picture — controls how much color appears in the image. At its lowest value, all color is washed out, leaving only the highlights. |
| • | Shine — controls how much highlight appears on the surface of brushstrokes. Higher Shine values make the brushstroke look metallic. |
| • | Reflection — maps a clone source image or pattern onto the texture at a variable percentage. For more information, see Creating reflection maps. |
| 1 | Choose Canvas |
| 2 | In the Ambient Lighting area, make sure that the Ambient lighting check box is enabled. |
| 3 | Move the Brightness slider. |
To remove ambient lighting, disable the Ambient lighting check box.
| 1 | Choose Canvas |
| 2 | Enable the Enable Impasto check box. |
| 3 | In the Directional Lighting area, perform an action from the following table. |
Enable the Simple lighting check box, and click a light indicator on the lighting sphere.
Disable the Simple lighting check box, and click on the lighting sphere where you want to add a new light source.
Move the Lights slider to the left.
Disable the Simple lighting check box, and move the Lights slider.
Click a lighting indicator, click the Light Color chip, and choose a color.
| 1 | Choose Canvas |
| 2 | In the Directional Lighting area, adjust any of the following sliders: |
| • | Brightness — controls how much light the light source contributes to the overall lighting color |
| • | Concentration — adjusts the spread of the light over the surface |
| • | Exposure — adjusts the overall lighting amount from darkest to brightest |
