| • | To create a custom palette |
| • | To open or close a custom palette |
| • | To add items to a custom panel |
| • | To change the appearance of items on a custom palette |
Custom palettes behave like the standard panels. For more information about working with panels, see Rearranging panels and palettes.
| 1 | Choose Window |
| 2 | Choose New from the Custom Palette list box. |
| 3 | With the Create Palette/Add Command dialog box open, do one of the following: |
| • | Choose a menu item from a default Corel Painter menu. |
| • | Choose a menu item from the Other menu to add additional controls to a custom palette. |
| • | Choose a menu item from the Panel Menus menu to add a panel, or any of the items included in a panel’s options flyout menu, to a custom palette. |
| • | Choose a menu item from the Tools menu to add a toolbox tool to a custom palette. |
| • | Choose an item from an open palette. |
| 4 | In the Create Palette/Add Command dialog box, click Add, and then click OK. |
If the item that you want is represented on a panel with an icon, you can create a custom palette by holding down Shift and dragging the icon out of a panel to the application window. This method works for brush variants, paper textures, media, such as gradients and patterns, and nozzles, looks, and scripts.
| • | Perform a task from the following table. |
Choose Window
Choose Window
| 1 | Do one of the following: |
| • | (Mac OS) Holding down Control, click an item. |
| • | (Windows) Right-click an item. |
| 2 | Perform a task from the following table. |
Choose Set Custom Icon, and locate the image you want.
Choose Text View.
Choose Icon View or Wide Icon View.
To change the size of the icons, click the Options button in the custom palette, and choose Small Icons or Large Icons.
