You can use Quick Clone to automatically set up everything you need to clone an image. When you use Quick Clone, it automatically:
You can also change the Quick Clone preferences. For more information, see Setting cloning preferences.
In the Clone Source panel, enable the Show Source Image (with crosshair cursor) check box. |
If you enabled the Switch to Cloner Brushes check box in the Preferences dialog box, the last Cloner brush that you used is automatically selected. |
