Adjusting selected colors
The Adjust Selected Colors effect is similar to the Adjust Colors effect, but it works only on a specified range of colors within an image. You choose a color in an image and adjust colors within a range of that color. You could, for example, change yellow peppers to red peppers. You can adjust colors that are exactly the same as the color you select, or you can choose colors within a range, based on proximity (on the color wheel or the color space) to the selected color.
selective adjust colors
Selective color adjustments change only certain colors in the image.
The Range sliders determine the extent of the HSV color space around the selected center color.
By combining these settings, you can set up a very specific range of colors to adjust. For example, you can limit changes to a precise shade of red.
The Feather sliders affect the softness at the edge of the selected colors. These sliders can help you create smoother transitions between the replaced color and the original.
feathering color
A replaced color with and without feathering
You can choose from any of the following adjustment methods:
To adjust a selected color Back to Top
To adjust selected colors by using paper luminance Back to Top
To adjust colors by using image luminance Back to Top
To adjust colors by using clone, texture, or pattern luminance Back to Top
Choose Embedded Image from the Source list box.
In the Embed Source Image dialog box, do one of the following:
Choose Texture from the Source list box, and click a texture swatch in the Painter Textures area.
Choose Current Pattern from the Source list box, and click a pattern swatch in the Painter Patterns area.
Adjust Selected Colors controls Back to Top
The following controls in the Select area let you refine the color selection.
Hue controls
Saturation controls
Value controls
The following controls in the Replace area let you refine the adjusted colors.
The following controls can help you preview and reset adjustments.
