Applying the Color Overlay effect
You can simultaneously add color and texture to an image by using the Color Overlay effect. This effect allows you to coat an image with color. You can control the opacity and intensity of the color. To use the Color Overlay effect, you need to choose a color that you want to apply and then choose the method for applying the effect.
There are five different methods for applying color:
color overlay
Before (left) and after (right) applying the Color Overlay effect using the Paper method
To apply a uniform tint to an image Back to Top
To use image luminance to apply a color overlay Back to Top
To use paper texture to apply a color overlay Back to Top
To use clone source or pattern luminance to apply a color overlay Back to Top
In the Clone Source panel (Window Clone Source), choose Embedded Image from the Source list box.
In the Embed Source Image dialog box, do one of the following:
Choose Window Media Panels Patterns, and click a pattern swatch in the Painter Patterns area.
To use a layer mask or channel to apply a color overlay Back to Top
Color Overlay controls Back to Top
