Corel Painter Help :
Painting : Constraining, fading, and undoing strokes
Using the freehand stroke drawing style, you can constrain your strokes to a straight line. The angle you draw depends on the orientation of the stroke.
You can also make a stroke less opaque, or more translucent, by fading the stroke.
In this example, a brushstroke was applied to the canvas (left) and then fade was applied to the brushstroke (right) by using the Fade dialog box (center).
In addition, you can undo a stroke. You can also control how many individual strokes can be undone, see Performance preferences.
The Preview window displays the results of your selection. |
Choose Edit Undo Brush Stroke. |
![*](images/tip.svg)
You can also undo a stroke by pressing Command + Z (macOS) or Ctrl + Z (Windows).
